- 11-25-2012, 09:20 PM #2876
- 11-27-2012, 08:24 PM #2877
Re: [ROM][BETA] Quattrimus ICS
- 11-27-2012, 09:41 PM #2878
You could ask on the samurai devs thread.
http://forums.androidcentral.com/sho....php?p=2300505
Sent from my GT-P7310 using Android Central Forums - 11-28-2012, 02:41 PM #2879
hey you guys i need some serious help. i was running cm9 beta 3 and the gsp has never worked it always said searching for gps. so while trying to fix it i stumbled on a thread that said it works fine in the stock rom. so i flashed the stock rom gps still said searching for gps. so i went back to recovery cleared everything and did a restore on cm9. it restored fine problem is the phone wont turn back on it just keeps booting to recovery. ive tried just about everything but im stuck in recovery loop. PLEASE HELP!!!!
- 11-28-2012, 03:11 PM #2880Thanked by:
- 11-28-2012, 03:21 PM #2881
- 11-28-2012, 03:23 PM #2882
- 11-28-2012, 03:40 PM #2883
- 11-28-2012, 03:50 PM #2884
Try wiping and flashing cm9 beta 3 again if that's the rom you want and start again from scratch?
Edit:Ninja'd glad you got it fixed
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmwareThanked by: - 11-28-2012, 11:47 PM #2885
- 11-29-2012, 12:04 AM #2886
- 11-29-2012, 11:49 PM #2887
Oh wow if I said beta 3 my bad. I was kind of panicked because my phone was stuck in a loop and I was waiting for an important call from insurance lol if I said 3 my bad, it was two. I was looking for fast answers lol
Sent from my LG-VM670 using Android Central Forums - 11-30-2012, 02:57 AM #2888
beta 3 was the test for the multiple device auto recognizer/installer... someone please correct me if im wrong...
- 11-30-2012, 06:31 AM #2889
I think it was called beta 2 pre 3. That's why y'all are calling it beta 3.
Sent from my LG-VM670 using Tapatalk 2Thanked by: - 11-30-2012, 10:01 AM #2890
- 11-30-2012, 11:29 PM #2891
I miss TDM. I has a sad...
Thanked by: - 12-02-2012, 08:36 PM #2892
Re: No-charging issues [(hopefully) SOLVED]
In case someone reads this, I forgot to follow up on this: I posted the above while in Europe (240V). I had been there for a few weeks and tried nightly builds regularly, but still couldn't get the phone to charge (only in the stock 2.2 ROM and some other early Android-version custom ROMs), until all of a sudden it worked really well with the above one. A few days later I got back to US (120V). I am not sure if it charged here my first day or not, but the 2nd day it did not and I needed to flash back the stock ROM again. Very annoying. I gave up. Last week I tried to flash a few other Android 4.0/4.1 ROMs, but same "no-charging" problem. Although I doubt it, I'll see if it works when I got back to Europe over Xmas. Maybe. FYI, I've tried with heaps of different chargers/cables both in the US and in Europe (also the same on both continents). After all the troubleshooting I've done, my best guess as an CS engineer is that there there has been an update in the part of the kernel/drivers that is responsible for charging.
- 12-02-2012, 09:33 PM #2893
That stands to reason, but something must account for some people having no problem. Is your OV the newer generation with the Hitachi screen? Maybe it's a driver interaction with the screen driver.
Repensum Est Canicula - 12-04-2012, 10:53 AM #2894
FYI
--Chris [cole2kb]
"Any story about malware on any platform...without numbers is not giving you the full picture, and just might be more worried about getting your clicks than any real discussion."
Words to live by: there are always two sides to every story.Thanked by 5: - 12-04-2012, 12:50 PM #2895
Awesome. I figured Tom was just working on other things. You know a programmer is busy when he doesn't update his github in a while. My guess: family. Mine's been keeping me busy the last few months as well. Also, Christmas.
- 12-06-2012, 09:45 PM #2896
I'm not sure if this is the right place to post this, but hopefully so. I just flashed this rom and I'm loving it so far but I've encountered one quirk that's starting to drive me a little crazy.
Whenever I type in certain text boxes it seems to tell the keyboard that I'm typing a password or something because it locks the keyboard so that no suggestions occur. So for example, if I try to type something in the URL area in the browser, no keyboard suggestions (and no auto-correct). But if I pull up Google and type in the search box on the website, I do get suggestions. I have no idea what would cause this, so any suggestions would be greatly appreciated.
I have a VM670 (Optimus V), running the current AOKP build (not nightly).
Thanks! - 12-06-2012, 10:48 PM #2897
Guess whos coming back! - 12-07-2012, 11:24 AM #2898
That does make sense, but it seems to be inconsistent. If I go to google sometimes the search box (on google, not the browser) won't let me use auto correct on the default browser. However it always lets me do so (in the website, never the browser) when I go to Firefox, or tell the website to pull up in desktop mode. I'm using swiftkey flow, and it disables flow (which needs the auto correct function on to work apparently), which is pretty annoying. But if it's a "feature" and not a bug that is good to know. Thanks!
Edit: It also happens when I try to name a folder in the Nova Launcher, which seems an odd place to lock down. Anyways, I just figured I'd find out if anyone else was having the same issue or had a fix. Thanks!Last edited by ItMoN; 12-07-2012 at 04:19 PM.
- 12-07-2012, 05:55 PM #2899
- 12-07-2012, 08:02 PM #2900
Folks: just installed the latest nightly along with gapps, and used titanium to restore all my apps. I have a 2gb ext partition, with plenty of room, but I am unable to update google maps - gives me an out of memory error. I've tried to get through this incredibly long thread to see if there is a solution. I saw some discussion about moving the data/data folder to SD card, and the risk if you boot with the card out. Can I just move the folder to the root of sd-ext, or is there more to moving it? Also, data/apps looks like it has a bunch of files in it, are those really just links to sd-ext/app, or can I delete those files to make more room on internal storage? Look forward to advice.
Reply
