89ideas
Hi miroslav thanks for the reply,after downloading what do I do,because I am just downloading it
Sent from my NX503A using AC Forums mobile app
I hope many Nubia Z5S will gather here... and will share each other experience
I use Nubia Z5S version 1.30
I install googleframework.apk, contactsync.apk, calendarsync.apk and all feature working perfect
I also installed these Apk into my friend Nubia Z5S mini...it also work there
I managed to solve the problem with finding the suitable ROM. it wasn't easy, looks like my Nubia doesn't like most of the ROMs.
Sorry, can you tell which ROM did you flash. And with which method you did that?
Thanks. Have the same issue
hello! this is the rom i used, no bugs, no glitches, phone just works fine.
/ and this is the guide if you need some instructions: i hope it will work for you as well!
