It's very unusual for a battery not to drop after 8 hours, even if idle (unless you powered if off).
A battery drain of 7.8% per hour doesn't mean anything if we don't know what else the phone is doing. If it's completely idle, then I agree, that's abnormal. If you're using it relatively often, then it can be normal.
