I have a 04 Chevy Colorado with a factory radio that I am looking to replace. It's a typical double din gm unit, so, if possible, I want to get a double din radio. I want something that makes phone calls through Bluetooth and can also stream the music from the phone. If I could stream music it through it as well would be great too. I looked at some of the app radios but most of the time I don't need all the functionality they offer, and sometimes that functionality isn't compatible with every android device. I looked at the Alpine CDE-W235BT which seems to be the perfect radio for me, however, owners of a galaxy S3 seem to have issues with Bluetooth music streaming or Bluetooth only connecting half the time. I really want the phone function to work well and reliably and don't want to have to try to connect the two every time I get back into my truck. As far as the Bluetooth streaming for music goes, if it doesn't work reliably, I'd just pop a flash drive in to play music.
Can you connect the phone using the headphone jack into the aux jack, and if so, will streaming from an app work that way? Will that influence the phone function? This is the problem with car stereos, if you don't know how to install them, they are not easy to return.
Thanks for any input.
Sent from my SPH-L900 using Android Central Forums
