Just got my note 2 last night. I drained down to battery showing 'yellow' probably almost red. Charged all night, started playing (nothing heavy used st all) and setting up my phone at 6:30am and was just on an hour call. It is now 11:00 am snd my battery shows 64 percent?? Wow, what sm I doing wrong?
Sent from my Galaxy Note 2
You actually might not be doing anything wrong. The greatest improvement in battery from the Thunderbolt to the Note 2 is idle usage (plus sheer size). On a Rezound battery, the Thunderbolt will drain about 4-5%/hour on wifi and about 10%/hour on LTE with the screen off. The Note 2 will drain about 0.5%/hour on LTE with the screen off.
However, if you are using the Note (which really just means having the screen on, since the processor is fast enough to not run down that much, in general), then I generally expect the battery to go down by 12% for every hour of screen time. So if I used the phone for all 4 hours, 11 minutes, I would expect the phone to be down to 48%. Where the Note 2 is great is that usually, you wouldn't be on the phone for 8 hours in a row. So a couple of hours in the morning, a couple of hours in the afternoon, and the phone would still be at about 40% at night. If the phone doesn't charge overnight, it will still be at about 35% the next morning. By contrast, with the same usage, the Thunderbolt should be completely dead by 4 or 5 in the afternoon, and if charged up to 100% again and unplugged (and LTE is left on overnight), it would be dead again before morning.
The battery meter is also amazingly accurate -- if I reboot the Thunderbolt, the battery meter might show 60% before the reboot and 35% after the reboot (no, the reboot doesn't take 25% of battery!). So when the Thunderbolt battery meter shows 40% (nominal), it's really more like 15% (actual), and it plunges from 15% (nominal) to 0% in minutes. With the Note, a reboot usually doesn't change the battery meter at all, or maybe by 1% or 2%. So 40% battery showing on the Note usually means that there are still 3 hours of screen-on time left. So the Thunderbolt is really, really deceptive that way.
In the other post where your battery was at 91% after 52 minutes, and screen was at 60%, that is consistent with having the screen turned on during the whole time (based on my 12%/hour usage estimate, I would expect it to have used 10.5% or so by that point).
Hope this helps.
