Doesn't seem strange to me... Did it last longer before? You could try the usual suspects: Disable Google Now and it's battery-draining location awareness and try running the device without the SD Card; if the SD Card is getting unmounted/remounted randomly and on its own, your battery drains by scanning the card when it's remounted, especially if you have a large portion of it used.
