Samsung Galxay Note 3 - Please help. My Magazine Swipe up Transition/animation not working.
mrwallyy
302
Re: Please help. My Magazine Swipe up Transition/animation not working.
Do you have a launcher installed? Perhaps it disabled it somehow.
FBA
Banned
Nov 10, 2013
821
I wish mine didn't work on a swipe up! There's no way to disable that feature. I don't know why it doesn't work for you however. If you figger it out let us know so I can disable mine!
stackberry369
1,400
I thought you could turn it off.
FBA
Banned
Nov 10, 2013
821
Not from what I have read, but if you figure it out, let us know please!!!
Roswell1
3
Hello, same thing here. I have the international version, stock rom. It happened a week ago, did a full reset and it worked again but just for a few days... It's annoying because animations are important to the user experience.
Also I have a problem with the light sensor, it gets brighter but won't get darker until I turn it off and on again... very annoying!
Do you a solution for the My Magazine animation ?
Note 3 user
21
I have notice that My Magazine Transition/animation when swiping up is not working. What could be the problem of this? Please reply.
I have the same issue, tried to reboot and it came back but soon disappeared again. Hoping for an update that solves this problem.
Roswell1
3
It sucks... I've tried to clean the data and cache of My Magazine but it doesn't work. It seems it's related to the launcher. I have no customization installed... I'm on official Samsung 4.3 UDMJ7.
Note 3 user
21
Hi again!
I think I may have an idea that works.
If you turn on developer options and go to the animations you should be able to turn them on: maybe the current firmware contains a bug that turns them off for some people. Since I do not have any animations at all this seems possible.
Note 3 user
21
Yeees it worked!
Here is how you do:
1. Enable developer options
2. Scroll down to transition animation scale.
3. Set it to 1x instead of "off".
Done!
Roswell1
3
Yes, it works! Sounds like there is a problem with the firmware though. For those who don't know how to enable developer mode, you have go to settings>general>about and tap the build number several times until it says developer mode has been enabled.
danishpeer
