Charging with 3.0 and 2.0 Cable
Omer San Gabriel
345
After some google-ing i learned that you can still use the USB 2.0 cable for data transfer in the Note 3. Is this also applicable for charging? And if it is. Using the wall charger while using USB 3.0 cable, does it charge faster than while using the USB 2.0 cable?
Thanks!
missmawarlina
47
Yes u can use the usb 2.0 cable for charging. It doesnt charge faster if im not mistaken. The voltage of the charging plug is what affects the charging speed not the usb cable.
Sent from my SM-N9005 using Tapatalk
jpr
1,700
48
You can use either cable but USB 3.0 will charge significantly faster when connected to a computer USB 3.0. It won't make a difference if using the wall charger as long as the USB 2.0 has a proper rating.
jpr
1,700
48
What do you mean by "proper rating"?
Not all usb cables can carry the higher amperage. Some will only charge at 500mAh or less even on a 2 amp charger. Cheap cables are famous for this although there are exceptions. You should look for a rating of 28AWG/24AWG marked on the cable. They will have a better charging rate than the 28/28 cables.
Omer San Gabriel
345
Thanks. Main reason of asking this is i'm planing to buy a note 3 and currently i have an S4 which has an USB 2.0 cable. Does the USB 2.0 cable that comes from the S4 is 28AWG/24AWG?
jpr
1,700
48
I don't have an S4 so can't say for sure but I would expect the cable that came with it would be of sufficient quality to pass the full charge.
Ladybell
52
you should be able to search the length of the cable and find the details of the cable . I have attached a pic to help with the visual.
Sent from my SM-N900V using AC Forums mobile app
Omer San Gabriel
345
Not quite sure if i read this correctly but i'm seeing AWM 21104 23WGX2C 30AWGX2C etc etc. (Sorry my eyes are starting to hurt.) xD
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
It might charge faster but when I connected my note 3 using the stock cable to a USB 3.0 port in my computer , I didn't notice any quicker charging. Theoretically you can see up to 900ma on a USB 3.0 port, but the stock charger is 2a anyway so computer charging would most likely be slower than wall outlet.
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3
jpr
1,700
48
The 2Amp wall charger will definitely be faster. That's why I said it wouldn't make a difference if using the wall charger as long as you had the proper quality cable. When using a computer you will get almost twice the charging speed on usb 3.0 vs 2.0. That's assuming your computer's USB 3.0 is a real USB 3.0.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Well, my note 3 detects it as usb 3.0 and I can put it in usb 3.0 mode.
jpr
1,700
48
There are native USB 3.0 and non-native. There are also low power and high power USB 3.0. They will both detect as USB 3.0 and go into USB 3.0 mode. They will not power external devices the same because they do not have the native power built in to do so.
FBA
Banned
Nov 10, 2013
821
What he said!!
smokedog87
