I received my Note 4 and love it, but my S notes can't be sync'd from my Note 8 or Note 10.1 (2013). Yes I can convert the old notes but then it limits me to only creating notes from the Note 4. They are obviously incompatible versions. I am aware of Lecture Notes, OneNote and Evernote, but I like the S note features and would like to stay within the Samsung eco sphere.
I did root my Note 8 and try the S5 notes from XDA, but it isn't syncing, have tried everything to get them to sync. Likely never going to happen.
So I was looking at the Note Pro 12.2, and wondered if anyone has the Note Pro12.2 and Note 4 and if the Snotes are compatible versions where a note can be created and synced between the two from either device.
Any help would be appreciated before I pull the trigger. Thanks.
