Samsung Smart Switch not recognzing Marshmallow
rmhenry1
I just updated my Samsung Smart Switch app on my pc, which says it should be compatible with Marshmallow. I downloaded the new Marshmallow OS on my Samsung Note 5 yesterday. Both PC and phone were rebooted after upgrading software. The PC Smart Switch app is not seeing my phone connect to the PC now. I never had a problem before and like Smart Switch for doing my phone backups after a big update. I'm using my Samsung cord furnished with the phone. Any ideas what the issue could be?????
Thanks!
:mad: rmhenry1
rvhs03
172
I had a similar issue as well. After updating android and smart switch on the pc, when I would connect the phone, smart switch would immediately freeze and stop responding. A restart didn't fix it and I still haven't been able to access smart switch. Definite issues there it seems.
mariusfilip
204
you could uninstall driver,then reinstall, have you disabled any system apps via the Debloater(XDA) or Package disabler pro?
Trees
1,544
12
38
I will check on this later this morning and see what happens. I did not update Smart Switch yet (saw the prompt to update to the Marshmallow compatible version) when making a backup before updating my Note 5 to Marshmallow.
KelseyRo4
317
I updated smart switch but it's still not working. When I try to back up my data, it goes to 93% then tells me the connection was lost. It's happened like 5 times in a row. Very upsetting!
Ryano89
1,265
I updated smart switch but it's still not working. When I try to back up my data, it goes to 93% turn tells me the connection was lost. It's happened like 5 times in a row. Very upsetting!
Sane problem here.
Verizon Galaxy Note5
Da Sko
Active member
Aug 11, 2015
28
Hello
I've the same problem here. Today I've upgraded my Samsung S6 to marshmallow and after that the smart switch doesn't backup anymore. I tried everything I could but nothing works.
oncevision
Once you connect you phone to your laptop, via USB cable, check the phone notifications. You will find that there is a notification that say the phone is charging via USB. Click for more options, Select the first option that allows for MTP. This should allow your phone to connect to Smart Switch and sync/backup your data.
Trees
1,544
12
38
Updated SmartSwitch over this past weekend, and then backed up phone. Worked fine.
Bastet2
I have a similiar issue with my galaxy S6 with Marshmallow. I downloaded an update to Smart Switch (ver. 4), and the issues started. First my laptop suddenly wouldn't recognize the cellphone, and some other issues, so I uninstalled and deleted S.S, and re-downloaded it. Same problem. Tried pretty much everthing everyone else here did, to no avil. BUT - the program will recognize the phone when I switch to PTP and then tells me it's an unsupported connection ... switch it back to MTP and I get the "plug in the USB" animation but nothing happens when I do. So now I can't bakup ANYTHING! Wish I had Kies back! At least it WORKED!
