Unfortunately, com.samsung.faceservice has stopped problem
msingh48
Active member
Mar 19, 2013
33
I am using note 5 920c.Two days ago I update phone to marshmallow. Everything is fine except phone showing 'Unfortunately, com.samsung.faceservice has stopped' repeatedly. Any solution please
nokia4life
853
10
It seems a lot of folks are having issues with services after the marshmallow update. That sucks seeing as how I was going to go back to using mine good luck dude.
Trees
1,544
12
38
I've had one process/service crash since the Marshmallow update, and that was Hangouts after its most recent update. I reported the crash.
I did not do a cache wipe or factory reset before or after the Marshmallow update. So far Note 5 continues to work well.
If you do plan on a factory reset, recommend backing up the phone first with Smart Switch. A factory reset will remove data.
tivativa
