I'm looking for a battery power pack for a backup. I travel a lot and don't always have access to a car lighter to charge. I have AC and car adapters that work fine but need a battery pack also. I've looked at a boat load of them but just don't know which one to get. Seen them from 3500 to 9500 MaH power.
If anyone has experience with these would you please share that. I'd like to get one in the next month.
EDIT: I thought I was in the Note 4 forum for this reply. So none of what I said below applies to the Note Pro 12.2 (which I have also). But, if you have a Note 4, read on...
If you find one that it's close to $50 you might want to just consider getting 4 extra batteries + two wall charges for the same price.
http://www.amazon.com/Anker-Batteri...ag=hawk-future-20&ascsubtag=UUacUvbUpU4579585
I got the batteries above and it's AWESOME to go from near zero charge to 100% charge in about 30 seconds (swap batteries).
That is, if there is nothing else you plan to charge with the external battery pack.
My experience with the external battery packs has been very mixed. If you find a deal that's really great, I'd probably avoid it. I had to send two back that didn't really work well or didn't last as long as you would expect, cords were very lose (wouldn't charge unless plugged supported) and would fall out easily.
Stick with a good name brand.
And your electronics take a REALLY long time to charge with the external battery packs. Typically for the battery packs that have dual USB outputs, one is normal output (2.2) and the other is slow (1.1, designed that way). So don't expect equal performance from multiple USB charge ports.
In the end, you are carrying about the same amount of stuff if you go with 4 batteries or an external battery pack and probably spend about the same $ (if you go with quality).
And in the end you have to either keep 4 batteries charged (about 3 hours each, but you'd have 2 wall charges so 6 hours total) or let the massive 15,000 Mah charger charge for about 12 to 14 hours (yep, it takes that long). So that's a wash too, maybe a bonus for the swappable batteries since you can cut the time in half.
My guess is that 5 batteries (4 spares plus your original) would equate to about 17,000 to 20,000 Mah charger capacity.
Pros and cons each way. Just thought I'd throw another perspective out there to consider.
