I factory reset my flashed Galaxy S3..why won't it work??
Misty Baker
I just had to factory reset my Galaxy S3 due to performance issues. It was originally Verizon but I had it flashed to Straight Talk last year. After the reset it will not make phone calls or send/receive texts. I have tried updating the software but it says it is unavailable. It also says "welcome to verizon wireless your mobile number is not active or invalid" when I try to make calls. The only thing I can think of is I did not remove the SIM card before the reset. Any help would be appreciated..thanks!
GSDer
8,471
15
Welcome to the forums!
I don't know anything about this 'flashing' business (unless it involves raincoats ) but you should be able to add the correct APN settings to get it work. Just do a search in the Verizon sub-forum and you should find what you need.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
drkrleitch
