clintw22
Thanks alot Clint...I've been trying to figure that one out for 2 days!!
No problem man! Glad to help.
Sent from my SCH-R970 using Android Central Forums
Hey, I just got my galaxy s4 quad core yesterday and I've been using it and I really do love the phone. However, one issue I'm having is battery life. It is absolutely shocking. As in the battery goes down one percent every 5 minutes, even if I'm just browsing the Web or reading messages. I don't know if this is normal or if I've got a faulty device that I should get replaced.
Here are some relevant images
Of what settings I have enabled
http://imgur.com/PKwPfQ9.png
And of my battery usage
http://imgur.com/3jAwRwt.png
If this is normal, is there anything I can do to help this issue?
#2. Google maps causes wake locks. What you do is clear data clear cache for that app. Then reopen the app.
Could you expand on this? What is this doing exactly and why does it help battery life? Thanks.
Apparently "Maps" shows on your battery drain % log whenever your phone queues your GPS. So when your weather widget is looking for location, if you search for let's say "Best Buy" and your Google Now is set up to give you directions to places you just searched, etc.
If you clear your map cache, it will won't do much for helping get "Maps" off your battery drain. It'll clear the preloaded map tiles that it saves to load quicker and that's about it.
Sent from my SAMSUNG-SGH-I337
Thanks! I had a feeling this was the case, but wouldn't it also clear any saved locations that it would later have to look for again, consequently taking more battery?
Didn't think of it that way, so more than likely you are right my friend. I'm not to keen on this stuff though so I'm not 100% sure.
Dropping one percent for every 5 minutes of usage is pretty good. Stop worryin about battery usage and enjoy your new phone.
Sent from my GT-I9100 using Android Central Forums
I have had my Samsung Galaxy S4 for 3 weeks now and I am having a horrible time with battery drain also. I went in to all my settings and disabled anything that may be draining the battery, stopped any apps that were automatically running (although honestly, since I spent $629 for a smart phone, I shouldn't have to stop the apps and widgets that automatically came with the phone and auto start every day considering they are one of the main reasons for having this phone in the first place) and I am still draining at an extremely high rate. I see some people are saying they can unplug their phones at 5:30 am and not have to recharge until 9pm, mine is no where to close to that. Standing idle, without me using it all other than to check the battery life, I was down to 50% battery within 3 hours. I played a game of Candy Crush and browsed Facebook for a total of 18 minutes, my battery life dropped to 28%. Is this normal?
I contacted my carrier who said this is an isolated incident (apparently not) and they sent me a new battery and I am still having the same issue.
I honestly think it's the device itself when I look at everyone else's screen shots on here because mine is so much different. I have Media Server 2%, Android System 3%, Maps 3%, Android OS 3%, Candy Crush Saga 4%, Voice Calls 4% and Screen 80%! I have the brightness down so low I can barely see it so this doesn't make sense to me. Does anyone have any ideas? I would really like to enjoy my phone and all its features without having to go through all this every day.
