ive been using my S4 Exynos for five days now. i'm just having problems connecting my S4 through wifi. It says "obtaining ip adress" when i connect and after it connected suddenly it will return
into "obtaining ip adress" status. I learned from my internet provider that i need to remove the wifi's password and it worked. Also, i can change WPA2Mixed into WEP setting so i can connect,
problem is i cant use wifi for my laptop if it is in WEP settings. Any help for this problem? TIA
