I upgraded my Verizon Samsung Galaxy S4 to 4.3 Jelly Bean. Since then, I started noticing a quirky issue in Gmail which I believe has to do with cache. When composing a new email, or forwarding an email, my contact will not appear in the recipient field when I type their contact 'name'. The search only works if I type the email address itself. Here is an example.
Contact Name: Jon Snow
Contact Email Address: gameofthrones@gmail.com
When composing an email, in the 'To:' area, while running 4.2 OS I was able to type either "Jon" or "gameof"and see this contact's name/email come up as a result. Now on 4.3, it is not recognizing the contact name, "Jon"... it only recognizes the email address "gameofthrones@gmail.com". As a test, I edited the contact and changed Jon Snow's name to "xx", saved the contact, then edited it again and changed the name back to Jon Snow. After doing this, I can type either "Jon..." or "gameof..." and both work! Something happened with this upgrade , and I can' figure out how to fix this issue globally for my Gmail contacts. Obviously I don't want to edit 1 by 1 each contact... Any ideas world?
