My fingerprint scanner has stopped working on my Galaxy 7 Edge, how can I get into my phone?
A
AC Question
My Galaxy 7 edge fingerprint wont read!
I just walked out with my new galaxy7 edge and of course the first thing I do is set up the lock screen. I registered 4 fingers on the fingerprint set up. It was working for literally 20 minutes then would not read any of them. I set up a backup pin, but its not presenting me with the option to enter it. I am now locked out for an hour....fornthe 2nd time. Is there something I need to do to enter the pin to unlock it? Is there a secret trick to the fingerprint reader? Am I doing something wrong?
H3aTeRzz
2,810
Re: My Galaxy 7 edge fingerprint wont read!
Hi
If you didn't have Android Device Manager, or Samsung Find My Mobile installed and active, then there's no way bypass its security. Sorry!
You can, do a full factory reset; this will get you back to what it was when you walked out of the store. Hope this helps!
Chris
tress
