i'll definitely keep that in mind, but again, there aren't many other choices out there that meet my needs in the near future, so I either keep my note 4 (and hold my breath for the marshmallow update) or I go with the S7 Edge. the Note 5 loses out due to being very similar to the Note 4, without the SD card option, and smaller battery, and no water resistance. looks like the S7 edge wins out, if I MUST get a phone this calendar year.
Seeing that you've been using Samsung for 2 years.
I'd suggest you go the Nexus 6p route. Trust me for a few things;
1. The Software. Stock android is nothing like touchwiz. In a good way. And there's no better feeling to get the update on the day it is released. It's soooooo snappy and you will not regret it just for this reason.
2. Screen size and front facing speakers. I see you watch a lot of media. Trust me when I say this, the front facing speakers and larger screen combination is unlike any other.
3. The built. While the S7 edge is the best looking phone out there. The metal game is a whole different story. I can't explain it. But you'll see when you get the S7 edge. Which you will I think.
Yes the 6P doesn't have water resistance. But it clearly delivers in many other areas better than the S7.
The S7 edge has water resistance and SD card over the 6P. But you can get the 64gb version for less than the price of the S7 edge. Or even a 128GB version.
Anyways. The decision is yours. Which I think you've made already.
But trust me, stock android, front facing speakers, larger screen and the metal body are VERY UNLIKE Samsung. Which you will enjoy and these features will feel fresh to you after using Sammy boy for two years.
