My 14 day return period is up tomorrow and i have decided to keep S7e! This is after having only iphone for the past 7 years and felt it was time for a change. Any tips would be greatly appreciated!!! Thanks!
Welcome to AC!!!
What are you looking to do? It's a tricky question... too many answers.
Oh, first tip... Go into the Display settings and change the screen density to condensed (unless you got it from Verizon wireless, who inexplicably removed the option)
It's like display scaling. You can read more on the screen. Same resolution, though.What does this actually do... I have a Verizon version so lol
If you haven't already shut off add-on-ware (ex: DTIgnite) under system apps I recommend you disable them. Try using "basic" for your screen display because that gives the most accurate color representation. Set apps to be shut down after they've been inactive for long periods of time in the power/battery settings area.My 14 day return period is up tomorrow and i have decided to keep S7e! This is after having only iphone for the past 7 years and felt it was time for a change. Any tips would be greatly appreciated!!! Thanks!
