Sorry, it's hard to see that image clearly on the desktop forum site. Can you post screenshots this way?
http://forums.androidcentral.com/ge...ide-how-post-screenshots-android-central.html
Also, in general, these are the screenshots that can be helpful:
Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main
Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
(I can just make out on your screenshot that your Cell Standby category is somewhat high, so that suggests your cell signal is generally poor.)
