Lawrie Sherratt
Try the smasung find and unlock my phone app via Samsung site. The link is in an earlier post. Good luck.
I´m facing same situation. I locked my S7 with finger print and when the phone reinitiated I had to place my password.The issue is that I forgot it. I log in android manager online and I try to unlocked the phone but the only option is to lock it.
Is there any way to unlock the screen without reseting the phone and losing the information?
even i face the same issue!!
SERIOUSLY IT SUCKZZZ!!
PLZ HELP ME OUT:-:'(
If you have a Samsung account and you set it up on the phone when you set up the phone ten log in from a computer or something and you can change the password remotely bypassing existing pSssord and stuff. Text me when u got it [number redacted by Mod] don't worry it's a daily. Number I change daily
This worked great for me. Note that you would need to setup your Samsung account in the app before hand. https://findmymobile.samsung.com/
Did it recently update to Nougat? If so, you might have to redo the print learning. That happened to meJust bought a new Sansung s7 and my fingerprint lock will not let me in! I have not even seen the contents yet! How to change back to factory ? Help!
