Hi to all , I am having a weird issue on my Galaxy S3; when my phone reaches around 2% I usually switch it off, plug it to the wall charger and the battery icon charge indicator is nearly at the bottom indicating that it is actually charging from 2%.
Last week, my phone reached 2%, so I switched it off, plugged it in to the wall charger, but instead the battery indicator went immediately at nearly half full, its as though the charge was not at 2% but at around 40 - 50%. So I decided to let it charge, after normal usage when it reached 2% a couple of days later I charged it whilst it was still on and upon a full charge I used battery calibration to wipe the battery stats and used the phone as usual.
Again after reaching 2% i switched the phone off and plugged it to the wall charger, only to see that the charge started again at around 40 - 50% and not at 2%; I am at a loss now as usually wiping battery stats works out fine, I also do not have the wipe battery stats in recovery so the only way to wipe battery stats is from the app itself, whilst the phone is on.
Can anybody help me out please?
Thanks..
Thanks..
