goproviders stopped workinf
JustJade
Active member
Feb 24, 2011
32
Hey all, a bit of help? I did a master reset on my Note 4 and my gear S, now I keep getting the error, "sorry goproviders has stopped." I don't get notified on my watch, however, I can connect via Bluetooth and remotely, I have cleared the cache and data on goproviders, restarted both devices, Uninstalled gear manager, and still no luck :( any ideas?
Dukins
738
23
Same problem here, did you get it resolved? I'm still looking for a solution....
You can't only uninstall gear manager. You have to uninstall all gear manager instances. Go to application manager.
Remove
Call Provider
Gear Plugin
Gear Module
goproviders
HostManager
Samsung Accessory Service
Samsung Gear
saproviders
SASystemProviders
svoiceprovider
Update Gear software
WordsTransfer
These should all have the gear icon next to them. Hope this helps. Only way I was able to fix it.
Joel Francis
The error message is being produced from the HBO app. Just open the app. If it still doesn't stop, uninstall and reinatall (if you want). HBOGO app has always had some issues on my Samsung Note 4 and Tab S 10.5
Remove
Call Provider
Gear Plugin
Gear Module
goproviders
HostManager
Samsung Gear
saproviders
SASystemProviders
svoiceprovider
WordsTransfer
dumpsterrentals38
