Gear VR disables vibrate function on Note 4 after use
TornadoQuake
Active member
Dec 3, 2014
33
After pulling out my phone from the Gear VR I noticed my haptic feedback function and all vibrating functions on my phone don't work. It only comes back when I restart my phone. There's nothing changed in the settings for vibration, though.
Anyone else have this issue?
Posted via the Android Central App,
AT&T Note 4!
TornadoQuake
Active member
Dec 3, 2014
33
I think I found a remedy. Inside, where your face touches, on the right side, there's a sensor that detects your face so it turns on the screen. You can hear it beep when you put on the headset. You have to eject your phone while it's in the "off" mode. You can tell when it's off by sneaking your phone out and noticing an X on the inner corner on the screen.
AT&T Note 4!
Thewhitecarno
