All posts. There is no color option in the text editor. When I update and save - I get the code..
The posts are fine as long as I don't edit them..
Edit: Opened this one in IE8.. and in Opera 11.. Now option for color. Thanx guys!
A few days ago we had an issue with someone using white text to embed Spam in a post. My solution was to turn color off for anyone with 10 or fewer posts. Unfortunately it didn't work the way it was supposed to and affected you as well. I've fixed that and I'm solving the text issue a different way so we should all be good now. The downside is if you use the color tag in any other posts, you will need to open the post in edit mode and then save it again. I did a few of yours for you. Sorry for that. I'll move this post to the Meta section later today.
