^Is that from an App?
Newbie here, thanks!
Is this normal?
My Precious Note2
And that is fin.Battery life outstanding.
Sent from my SAMSUNG-SGH-I317 running CleanROM 3.5 w/MultiView and Perseus Alpha29
What settings do you keep your phone at. Those are the kind of numbers I expected after purchasing the gn2 but so far im getting half tht. I ve been playing with the settings a lot to disable running apps I don't use and as well as playing with the screen brightness. I hate turning down the brightness because I love how vibrant it is but Im running out of ideas.
Here is what I'm doing:
1. On the advice received on the thread I posted, I've disabled all AT&T apps except for AT&T Messages (need it for visual voicemail).
2. I've disabled notifications on ALL apps in the App Manager.
3. I've disabled "Allow automatic updating" on all apps in the PLAY Store.
4. I've disabled Samsung Push Service.
5. I've disabled sync for all accounts except for my work email (Exchange). That account is set to use push 9a-5p on M-F. Otherwise its at manual.
6. Screen is set to 20% brightness.
7. GPS is off.
8. Wi-Fi is off when I'm not in a Wi-Fi area. For me, that's 2 hours a day.
9. Turned off all vibration settings that I could find. Two that still exist are the Facebook messages (when I have the app open and I get a message) and the calendar appointment reminder. I've not found the option to disable those individually (I don't want to turn on power saving mode to disable haptic feedback).
10. Ask for more tips on this forum
Here is what I'm doing Just in case.
7. GPS is off.
I cant complain! I did have a glitch that killed my battery in under 18 hrs, (damn Google Sound Search)-But since I disabled it, I'm getting almost two dsys....
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
