AT&T Note 2 - My MMS & Text Msgs Will Not Send.Well....l
pinknail
I have had no complaints for a year and a half with my Note 2, however last week I started getting the old "failed" message from my server when I would send a text or a MMS message. Do I have something set wrong? Keep in mind Im not quite as tech savvy as the rest of you seem to be. Thank you for any advice. And by the way, Ive been to ATT once, and they replaced the sim card thinking that was the issue, and yesterday I spent several hours on the phone with a technician. No help.
mrscaston30
Active member
Sep 13, 2013
38
I think I found a solution. For a couple days now I wasn't able to send and receive MMS messages but I was able to get regular messages. I am using goSMS to send and receive messages and I switched back to the stock app and still had issues so I searched and searched and I think I found a solution that might work for your problem as well. Try this and see if it works: Go to settings, more settings, mobile networks, access point names, and once in there you should see something that says ATT Phone and a green dot on the right hand side, click on the left soft key at the bottom and click on reset to default. Once you do that, you can either restart your phone or try it without restarting but go back into your text messages and try sending one out and see if that helps.
RandyRoyalty
