HELP: Bought an AT&T Note 2, but using on TMobile-CAN'T SEEM TO UPDATE TO 4.3
Apr 18, 2013
6
Hi, I bought a phone from an AT&T customer, and presently have an AT&T 4.1.2 build. (N7105 phone) But I am using it on TMobile. I want to update to 4.3. TMobile Samsung kies only tries to re-update to 4.1.2 and when I check for an OTA update (says through AT&T servers) it says there aren't any updates. It might be checking TMobile servers instead.
I have been into a Best Buy and the Samsung Rep flashed it with his laptop and all it did was flash to 4.1.2 AGAIN. He said maybe check out a custom ROM. I want Photosphere and Galaxy Gear capability as well as SPen support, etc.
Can I change to go through AT&T servers? (also the Samsung reps said AT&T was having problems with Gear support for Note 2) Any recommendations or thoughts on good custom ROMS?
Thanks!
David
tress
