Samsung exhibit 2 Andriod 2.3.6 randomly restarts... Please Help!
Okay... So for starters my phone (samsung exhibit ii android 2.3.6) kept restarting randomly. I have uninstalled my new apps but it still keeps restarting. It restarts about 3 times a day. Any help will be appreciated.
-Mark
*Also every time it restarts all my apps caches are cleared...?
Re: Samsung exhibit 2 Andriod 2.3.6 randomly restarts... Please Help!
I read this has something to do with the sd card???
Sent from my SGH-T679 using Tapatalk 2
Yes, it could be the sd card. What is the size of the card?
Is your phone rooted?
No it is not rooted
Quote:
No it is not rooted
Ok, what is the size of the sd card?
8 gb
Use a cache clearing app and an app called fast reboot. These may help but won't solve the problem.
Ok thanks
The "random restart" is a crash. You should power down and power back up after it happens, or it will just keep happening. If this doesn't solve it, power down, remove SD card, power back up and let it check media, then power down and put the SD card back in and you should be good.
Thanks
I have the same problem too. Is that only because of the SD card?
