Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By attweco
  • 1 Post By attweco
    Default Nexus S Facebook, LED, microSD, Email, Text, & Camera Workarounds
    The Nexus S is a great phone offering developers a "pure" Android experience. That purity brings limitations a typical owner may never notice. Here are resources for Facebook Sync, Notification LED, microSD, RAM, Speed Dial, Smart Dial, Lost Photos, Contact Groups, Email Search, 160 Character Text Limit, Camera Zoom, Browser Zoom, Video Formats, FM Radio, Visual Voicemail, HDMI, and Bluetooth.
    Facebook Sync: Android devices sync with Facebook but Google "...purposely removed the feature from the Nexus S..." The Nexus S doesn't sync Facebook Profile photos, status, messages, phones, events, birthdays, or notifications. Incoming calls don't pop-up with new profile photos and status.
    If you root, Cyanogen can restore Facebook sync. If not, you can manually update some Facebook info:
    (free, ) Get Facebook notifications, events, etc. Manually sync contacts & profile photos.
    • Manually import Facebook photos to the Nexus S with or .
    updates photos and birthdays. ()
    creates a file with name, birthday, etc. to import into Google Contacts (). article.
    Notification LED: The Nexus S does not have a LED for missed calls, email, texts, or events. Try as a workaround.
    • If you are rooted, try the to light up the buttons on a notification.
    microSD: The Nexus S has 16GB but no microSD for added music, photos, and movies. Cloud storage options can help if needed.
    stores up to 2GB ( for 2.25GB) for free. Open with the .
    can store your music to play with the app. can store your doc or xls files for use by the app.
    RAM: Androids may have 1024MB of RAM for apps and operating system. If the is an issue:
    • Remove apps that you don't use and use an app like to move apps out of the internal memory and onto the internal SD card.
    Speed Dial: The Nexus S doesn't have Speed Dial to assign contacts to numbers 1 to 9.
    Smart Dial: The Nexus . "T9" lets you type a name such as: 2 for B, 7 for R to see names beginning "Br".
    There are some good phone apps that can be used in place of the stock Android phone:
    • Create a homescreen of dialing shortcuts: Long-press an empty spot > Shortcut > Direct Dial
    lets you dial a middle part of a name or number. For 202-456-1414, you can dial "456" or "1414".
    lets you dial their initials for instance dial 2 for B, 6 for O for Barack Obama.
    & can search contacts for "Pen" for contacts on Pennsylvania Ave or "Wash" for Washington.
    Gallery: Nexus S owners have found relief from the lost photos, wrong photos, and slow photo loading with the app.
    : let you group contacts to send a text or email. The Nexus S can't edit contact groups. Workarounds:
    • Setup contact groups on your PC at . Use ($1) to setup contact groups from your phone.
    • Use a free app like to group contacts (also a smart dialer)
    Email: Nexus S Email search is limited and can't , Try (Free) or Exchange ($20, free trial).
    Messaging: The Sprint Nexus S 4G Message app stops at . or (free) do not.
    Camera: The Nexus S Camera lacks but there are many great camera apps that do.
    ($4, ), ($4, free )
    (free) shots bursts. ($2) is fast. (free) adds more effects.
    Browser: The Nexus S browser has , and limitations. Consider browsers like or .
    Video Player: The Nexus S does not play video formats other Android phones play such as DivX and XviD. Android Market offers workarounds:
    to a format the Nexus S can use.
    (Free, ), (), & add many formats. is great but adds no formats.
    FM Radio: The Nexus S so consider () for local AM/FM stations. Also try , , and .
    : shows the caller photo while playing their message. A slider bar lets you play a certain portion as you would an MP3.
    • The Nexus S lacks Visual Voicemail. is a workaround but costs .
    HDMI: The Nexus S USB port does not serve as an HDMI port but the for wireless HD.
    Bluetooth: The is faster and uses less power. The . Use WiFi when you can.
    HD Recording: Some Androids record HD Video. The . There is no workaround but is this something you need?
    Keyboard: The Gingerbread keyboard is good but some prefer , , or other Keyboards.
    See the Getting Started guide and Phone Comparison for more. This information was drawn from many gurus including igotsanevo4g,
    ragnarokx, and especially Baconator 's thread [How-to] Nexus S Answers. Thank you! Also see the .
    — Milo
    ← Tap Getting Started at the top of any page for help with:
    - Settings - Email - Backup Everything - Phone - Messaging - Music & Photo Sync
    - KeyboardsFolders - Favorite Apps - Extending Battery Life - My Avatar
    - iPhone User's Guide to Android - (Palm) - Tablet & Phone Comparison - Epic4GT - ATT - TM
    If this helped, please click Thanks & Like↓
    Thanked by 3:
  2. #2
    Makai5's Avatar
    Posts
    Global Posts
    34 Global Posts
    Default Re: Nexus S Facebook, LED, microSD, Email, Text, & Camera Workaro
    I just got this phone and I'm staring to find out that it lacks the things that i like. I should of done more research.
    Quote Originally Posted by Makai5 View Post
    For some, the missing features are like a puzzle they get to solve.
    For some there is no more fun than spending a weekend trying to get something on their phone to work just right.
    For others, that would be a weekend from hell.
    — Milo
  4. #4
    attweco's Avatar
    Posts
    ROM
    Stock
    I'm VERY interested in the Nexus S.
    Would rooting and CM7 supply many of the functions which are missing out-of-the-box?
    Change is good!
    Quote Originally Posted by attweco View Post
    Yes, CM7 can help with many of the missing software features. Others can be fixed with replacement apps.
    As to the microSD, Notification LED, HD Recording, RAM, HDMI, Bluetooth 3.0, and FM Radio, software can't fix hardware, these are truely workarounds.
    — Milo
    Thanked by:
  6. #6
    attweco's Avatar
    Posts
    ROM
    Stock
    @milominderbinder: This is great information. Thank you very much.
    Change is good!
    Thanked by:
    milominderbinde likes this.
    You are welsome. If you find anything that could be added, please PM me!
    — Milo
  8. #8
    attweco's Avatar
    Posts
    ROM
    Stock
    Two really excellent suggestions of yours were "MoboPlayer"(works great for my .avi files) and "NoLED", which is the perfect solution for the lack of a notification LED in the Nexus S. Especially NoLED, because it also does notifications for my "FlightTrack" and "Parcels" apps, in addition to the usual Gmail, Calendar and so on.
    Change is good!
    Thanked by:
    Thanks. I am just compiling the work of at least others.
    If anyone has any other workarounds, please PM me.
    — Milo
