anyone comment on streaming bluetooth... and what are you comparing it too....
thanks-
Listening right now via headphones (plugged into the jack) and its just...OK. My old phone is an LG G2 and it was capable of going higher than I would ever need it to so I would never really listen at 100% anyway.
100% on the 6P seems just a bit too quiet for me.......Im guessing Viper4Android can take care of it but bumping some levels up.
I havent tried via bluetooth yet
My 6P just arrived, and this issue is definitely high on my list to test over the weekend. I'm also coming from a G2 and have never had any issue with volume.
As an aside, are you also finding it tough to not accidentally hit the power button and volume rockers on the 6P? I'm so used to them being on the back and being able to manhandle the phone however I want, I keep forgetting they're there.
Rockers arent an issue for me. Though I do miss the rear setup from the G2. And the double tap to wake (although that seems to be fixed with new kernels)
On bluetooth earbuds and speakers, it is plenty loud. No problems.
I was coming from a galaxy s6 .. and YES.. the headphone volume on the S6 was blasting... 6P ..not even close..
I was using Monster in ear sport headphones on Both devices....
Using Slacker and or Pandora same low earphone volume on the 6P
