Maddog241
Anyone who flashes this, can you report back to what the baseband/radio info is. Thanks
Flashing now...Will have that soon for you.
Baseband version: 1.48.00.817r 0.01.78.802w_3
Voicemail notifications appear to be broken still.
Silly, but how about the camera?
The VM notification bug is the only major problem I have with the previous leak. I can live with the camera/Gtalk timebomb and the fact that it resets my VM number to default every time I reboot, but the VM notification issue is critical. O hope this fixes it!
Sent from my Tbolt using Tapatalk
Why do people still use the Verizon voice mail?
Why should I use something other than VZW VM?
I've always used the carrier's voicemail because it just works. No app to download or anything to configure. And it doesn't require a data connection in order to get voicemail notification or to retrieve messages.
Google voice...free visual voicemail, customized answering messages, you could check your voicemail from a computer, it works, the app is snazzy
The point being made was that the stock voice mail notifications didn't work...so the "it just works"argument doesn't really hold up
