AT&T KitKat for Samsung Galaxy Note 3 - Report Issues and Problems Here
greg24
Active member
Aug 30, 2013
25
Re: AT&T KitKat for Samsung Galaxy Note 3 - Report Issues and Problems Here
Its doubtful that it will work if it keeps doing that. As I said in an earlier post, my wife's phone that I bought off of ebay, still, will not even upgrade to the Pre-KitKat NB4 Version; I strongly feel its because we didn't purchase & activate through at&t. If you're not rooted, or rooted previously, then my guess is that you'll need to contact AT&T to get support for your issue. Are you running the NB4 Firmware?
I bought mine through att
jlh73
377
Anyone use the stock messaging app? When I get a text it looks different than before. The person's texts are all one after another then my replies. It doesn't seem to be in order the texts are sent or delivered.
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
H3aTeRzz
2,810
Well if you're having issues downloading or installing, you should contact AT&T, they can push the download to you if its showing that you "have the current" but don't. Now, if its failing during install, then they probably will not be able to help you if a hard reset doesn't help you, if that's the case, in that install keeps failing, and you've not rooted, then a warranty issue might be in order.
jlh73
377
Mine would fail also at 27%. Took it to AT&T and they replaced it. Got home and the update worked. But I've had about 3 random reboots in 24 hrs. Never had one on 4.3.
Delo773
Active member
Feb 15, 2014
29
So still no option to turn mobile data on from notification bar is it
Well at least I can. .
iphone|iphone3| and then i met android samsung and my world change. note 3 owner
H3aTeRzz
2,810
Interesting regarding the reboots! Sounds like att needs to fork over another one. The one I got from att Monday, updated fine to Kitkat and I've had zero issues.
jneusch
1,148
31
Yes. That's the only issue I seem to be having. I haven't figured it out yet.
jlh73
377
Seems to be more wide spread than just AT&T 4.4.2 from what I'm reading.
gadget22
Active member
Feb 4, 2013
32
Is it possible to use emoji's with swiftkey? If so what do I need to do?!?!?
H3aTeRzz
2,810
It almost seems that an app (that might not be compatible with KK 4.4) might be causing the issue for some. I say this because there are so few of those issues reported happening. Here's what you can try, it the reboots continue. Turn off all unnecessary apps using Application Manager. If the problem stops, then start turning on your apps one at a time to see which one might be causing the issue. Time consuming, but the alternative is to take it back and get another one.
blackmagicwoman
Trusted Member
Mar 27, 2014
119
On AT&T Kitkat you can use Swiftkey beta to get emoji's.
Sent from my SAMSUNG-SM-N900A using Tapatalk
almarsh78
69
After the update the phone does seem more responsive and everything is working great except now my bluetooth is destroying my battery. I have it on 24/7 either paired with my headset or my car. In 6 hours with little use my battery is down to 62%...25% showing as bluetooth.
H3aTeRzz
2,810
Try clearing cache for bluetooth in application manager, then turn airplane mode on then off.....then reboot phone, Worth a shot.
Jan 7, 2013
13
Original s-view case would not work with home button.could trigger by s-pen removal or power button . keyboard issues like correct an freeze.an a serious difference in battery usage.
ehosey2
547
Battery seems to be settling in nicely but that stupid unstable internet message still pops up.
Sent from my Samsung Galaxy Note 3.
jlh73
377
Anyone's text not in order?
pmr6644
Active member
Jul 28, 2013
39
I'm getting huge battery drain from android services. My phone dropped 12 percent in two hours with the same settings I had before the update. This is not acceptable. My android services is draining more battery than my display.
wuaoshi
I updated mine but as soon as it rebooted, it started freezing and now every time I reboot it, it works for about 30 seconds and then it just freezes up again. I cleared the cache and did a factory reset but nothing.
H3aTeRzz
2,810
The bottom line is..."some" may get away without doing a Factory Reset, yet there are others, to whom complain about these issues mentioned above, that "will" require a Factory Reset. Get Kies 3, backup your device, do factory reset, then restore. This "should" resolve most issues.
