Battery Icon now White
utahbronco
I'm a pretty unsophisticated Smart Phone User. I've had my Samsung Galaxy S4 from Verizon for about 2 months now. I love it!
I was asked yesterday to allow a Samsung Software Update, I said yes. It went smoothly and rebooted the phone. This morning as I unplugged it from it being charged I noticed that the Battery Icon is white. I swear it was green yesterday or the last time I remember but now it's white. After lots of looking I believe that it isn't the Samsung Software that controls that, it's the Android Software that is in control. I don't remember Android asking to update a software release, just the Samsung Software. The Samsung Software update was for SCH-1545-MK2 to NC5. I'm at Android level 4.4.2. Can anyone confirm that it's the Android Software that controls the color of the status Icons on the top of the screen? If it is Android that controls the color of say the Battery Icon, can I change that? Can I go back to a lower release level of Android or would I be asking for problems. Thanks in advance for helping out a new user, I appreciate it!!
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,366
115
63
Android 4.4 did change from Halo Blue to white. You can change that color, but it will involve rooting your device. Something I would not recommend for a person new to Android, or if that is the only reason.
I actually welcomed the change. Halo Blue was getting old.
keruss
I would like to know if this can be changed as well. What I think the original poster is requesting is to have the battery icon be green for full or yellow for almost empty to red for close to dead. Now it is just white for any phase. Does anyone know if this can be changed back to display the battery life indication levels? I am not sure what the halo blue is referring to, but I want the green/yellow/red battery icon, not just white all the time for any level.
joemontana
168
I would suggest having it show the percentage of battery life.
Go to settings-more-battery, at the very bottom tick the box.
I find this very handy!
bigredgonzo
145
Just to clarify a bit for the OP. Yes, your update said it was from Samsung, but the update actually originated from Google. Google puts out an update for Android and then the manufacturers modify it for their hardware. After that, the Carriers update it again for their purposes.
Google (Android) did change the icons to all white and changing that does require root access, which really isn't worth the effort to just change the icons back to colored.
BigRedGonzo
Mohamed Jiffry
capcut pro apk download
