dss2000
What I found is that for USB chargers you need a "charge only cable", data cables shorted otherwise you will only get 500mA no matter what chargers its in and when you look at your battery screen in settings it will say "charging USB". The non USB car chargers like the the Motorola Micro-USB High Performance Car Charger will say "Charging AC" and will give you 950mA. The Samsung AC charger charger that comes with the phone is rated at 950mA. I did a calibration run from 1% charge to 98% on a 2100mA battery and it charged in 1hr 54 min which if you do the math comes out to 1,065mA which is about right. Battery Monitor Widget was initially reading 1574mA then decreased to 314mA by the time it got to 98% but when I took an average of all the mA readings along the way it came to 1,100mA so I think the Battery Monitor Widget is accurate. It makes sense that the current is higher when the battery is empty and decrease as it gets full. People have said that the Nexus will only take accept 1A but I don't think this is right, When I run Navigation/Pandora turn autodimming off so the screen stays bright I can draw about 1,200 mA. If I plug in the 1 A Motorola charger it can barely keep up, maybe be positive by 100mA, If I plug in the 2.1 A charger it will be positive by 500mA. So if you go from -1,200 mA to +500mA you have to be drawing more than 1A. Some will again say it can't charge more than 1A but even if you don't believe Battery Monitor Widget and 1A is the limit how can you explain the difference between a 1A charger and a 2.1A charger. Even if you don't believe the numbers it is giving you can see that the battery % charge is staying even with the 1A charger and gaining with the 2.1A charger. Perhaps I will post a full review and screen shots.
Attached is a screen shot of it charging, top graph shows how much mA it is receiving, a positive number because it is charging. The lower graph shows the % charge of the battery
If you don't want to make a charging cable looks like there is one here you can buy:
https://forums.androidcentral.com/e...ource=vb_ac&utm_medium=content&token=W9_7Dcl7
