I dropped a couple of boot/shutdown animations on the OP.. They may work - just pulled the links from XDA.. Let me know if they work for you.
They are flashable in Recovery.
the phone keeps freezing up in CWM (green) 'Installing package.' Any suggestions?
A couple days ago I got the droid pissing on the apple 2 work, but it only runs on start up n was wondering how I could get the/an animation for shutdown
For superclean .4 stupidfast 12/20 kernal? I didnt upgrade... Waitin for a less buggy version of dl30 superclean rom I like my fone on superclean .4 alot jus wish it had flash player
I downloaded android peeing on apple and moved it to my sd card. i went into cwm and found it on my sd card and clicked to install it. my phone gets stuck when it says installing update...i wait 10 minutes with the screen like that before i took out the battery and turned my phone on again....anyone know what could be causing this...im running RubikS...thanks
Does anyone know of a way to make the korean boot anaimation (.qmg file) into a bootanimation.zip? The .qmg type works great on EB01 with a stock kernel, but as soon as you install a voodoo kernel, its ruined. The voodoo kernel installs its own bootanimation.zip that can easily be removed from system/media, but even if you remove the .zip file, the korean boot animation is ruined because of a flashing box in the dead center. Im guessing the kernel needs to be modifed to fix this problem, so it might be easier if someone were to make a .zip of the korean .qmg file. Thanks for any responses or help.
