Cases anyone?
Ranjen617
286
22
18
I can't seem to add permissions for this app to show a picture but I ordered one from Amazon in a pretty pink with the magnetic ring. 13 days later the pink is peeling away from the case. I added a review on Amazon, so read the reviews since I can't share here. I like the case but it's not durable.
Reactions: J Dubbs
Bkdodger1
3,647
2,261
113
Benks case showed up today .. Will the real slim shady please stand up
J Dubbs
4,006
1,145
113
Thanks ...much better now handling this phone ..first day took it with me to work ..waiting on my Latercase which should be here tomorrow...same style case except they cover the camera holes
The Flips are too slippery to be folding and unfolding all day without some kind of case, even if it's just for a better grip. I'm not sure why they didn't give them more of a textured surface, being that they're so small and slippery 🤔
At least they're not P6Pro slippery, that thing is the most slippery phone I've ever held.. it will slide off pretty much any surface, it's like it levitates.... what was Google thinking? Lol.
I like the way your current case outlines the cameras, gives it a classy expensive look. And the cutouts for everything, and fit and finish look superb. I honestly prefer that over the Latercase looks wise. I'm going to keep Benks in mind for some future cases if it holds up for you as well as it looks 🤩😉
Reactions: Bkdodger1
Bkdodger1
3,647
2,261
113
Yes I agree the sides should be more grippy and without a case it will slide off many surfaces including wireless charging I’ve seen that before on previous Flip …Latercase came in will post up next post and unfortunately got a dud with the bottom part fit is loose smh
Reactions: J Dubbs
Bkdodger1
3,647
2,261
113
Here's the Latercase .. top portion by the camera fits perfect but the bottom is loose when I grip it I could feel it creaking a little bit and it slides off really easily when you want to remove the case we shouldn't be that way...
J Dubbs
4,006
1,145
113
In the sixth pic down I can see the top of the bottom half is bowed out by the hinge, that's the issue, too much space... it needed to be slightly smaller cut for a tighter fit. Honestly the other edges look a little rough cut as well. Plus the kevlar doesn't seem to be as nice looking as the Benks either ☹️
Lew from Unbox Therapy is the owner and designer of those cases.... they didn't used to be cheap. It looks like the quality has went down unfortunately 😕
fuzzylumpkin
5,555
2,558
113
So a bunch of big promises turned into just YouTuber merch. Shocking
