Sadly, there is no way to clear system cache when you boot into recovery. The option is missing from the list.
Only way is through storage > apps.
wamp wamppp
wamp wamppp
Watsup Diddy. The Z2 Force is running 7.1.1 It was still there on the Z1 after the update to 7.1. Does wiping the cache through storage accomplish the same thing or is it different?
It's possible. Personally, I've never done a factory reset after a system update. Never needed it, wiping the cache partition and clearing cached data is been always enough for me.Thank you. Does this mean we can look forward to less corruption from new updates? I used to always factory reset after most updates on my previous phones, and when I did not, something definitely screwed up.
