tat21985
This thread is awesome! I am so glad I was able to find these, I really didn't wanna have to root in order to change the font..
I have added 85 additional fonts. If anyone would like to make a preview of each and post, have at it. Otherwise I am just including a screenshot of fonts in the zip file.
Um, no. What he's asking is how to share them with an app that asks where to find your font files (in this case, Minimalistic Text Widget, the same app I'm back to ask questions about). This app, before Android allowed easy customization of fonts, allowed you to set a fonts folder it would scan, offering you the chance to customize the widget(s) with any font(s) you liked. The setting has not been changed in the app, so being able to tell it which folder contains the font files would let us use these fonts for that app, and others with similar settings.See post #1 or #17.
What these "font apk's" do is change the system font on your android and allow your whole system to utilize. I am not familiar with the Minimalistic app, but if you install one of these then it becomes your "default" font for the system. In which case I believe "Minimalistic Text" would also use this font as it is the "default" font (the Minimalistic app should be able to ask you which font to use, in this case choose "default". Again, I am not familiar with that app. Furthermore, if you need to locate the directory structure and extract the fonts to place in a certain folder then that would be (I will use "Opificio" as an example): System root>Data>Data>com.monotype.android.font.Opificio>app fonts>Opificio>TTFUm, no. What he's asking is how to share them with an app that asks where to find your font files (in this case, Minimalistic Text Widget, the same app I'm back to ask questions about). This app, before Android allowed easy customization of fonts, allowed you to set a fonts folder it would scan, offering you the chance to customize the widget(s) with any font(s) you liked. The setting has not been changed in the app, so being able to tell it which folder contains the font files would let us use these fonts for that app, and others with similar settings.
When i click to download it it says download unsuccessful your phone does not support this.. I have a galaxy s2.. Any ideas?
These are apk's just like an app that you would download from the app store. Instructions are in the 1st post. Save it to the root of your SD card and install the fonts you would like. Once you install go to menu>display>font>Select the font you want.so when u download the font what do u do next because I cliked on the dowload link but idk what to do next
