[COT NG][TOUCH]Project Open Cannibal Touch
nitemarenet
20
Re: [COT][TOUCH]Project Open Cannibal Touch
There's no touch ability on the image i flashed, its all text driven.. wrong image?
I should correct myself, home/menu are Down/Up respectively, and back/search both do "back" function.
RavenPhoenyx
4
Alright, so I went to install the COT recovery. I have made flash_image executable and followed the instructions to install the COT Recovery 2.1. It seems to work fine, via the adb shell, but when I adb reboot recovery, all I get is a light blue screen that says Enter the fastboot... Enter the fastboot.... Long time no see! I don't remember having ever installed or used fastboot, especially since this is the first I have messed with installing a recovery or anything since I rooted. Any help would be appreciated. Also, I didn't get a logcat to post, as it has never kicked an error.
anon(963605)
393
You are on ZVI (Ice Cream Sandwich) right? If you are you have to be on ZVD (Gingerbread).
Sent from my LG-LS840 using Android Central Forums
RavenPhoenyx
4
Ah, I see. Is there going to be support in the future for COT on ICS or is there another good functioning recovery that I can use with it?
thenameisnigel
1,446
148
63
ICS isn't supported by any recovery on the Viper. I tried hacking away at the bootloader, but looking at the Optimus G and the LG Lucid, they go back to Gingerbread before they flash any roms, therefore meaning that no one was successful in hacking the bootloader. ICS will probably never be supported.
sokkershark
15
So this recovery only works with gingerbread.... i was updated a while back to ics through the auto updates. is there a method (unbricking?) to downgrade to gb so i can install the recovery?
thenameisnigel
1,446
148
63
The unbrick method is the safest way and only way to downgrade.
Sent from my SPH-D710 using Tapatalk 2
nitemarenet
20
I've been working crazy hours the past few days. Has there been any update on this? I still haven't been able to flash/wipe/anything with this recovery. I'll help anyway I can, even if it means going through code or building it. Let me know.
thenameisnigel
1,446
148
63
I'm going to update it sometime today or tomorrow. :)
anon(963605)
393
Format() expects 4 args, got 3
E;Error in /sdcard/pandarom.zip
Status 7
Sorry I couldn't do anything any thing else I have no computer to do it with.
Sent from my LG-LS670 using Android Central Forums
sokkershark
15
Tried this recovery today I think there is a select problem still. Holding down the power button for bit longer than an instant gets you to the next menu, but do it again sends you back to main menu. Anyone fixed this yet?
dxter
