So in short my Droid Charge's SD card is screwed up.
I keep getting the message Damaged SD Card message in my notifications and I click it every time to format but then it doesnt do anything. When I try to view my photo gallery it says the sd card is blank or that there is no sd card. It wont let me use the camera because theres no sd card.
I'm rooted running Tweaked 3.0 with the latest FP5 updates after unrooting back to stock in order to get them. Tried to Odin back to stock a few times and then reflashing Tweaked a few times and still the same thing. Did factory/data reset, cache wipe, dalvik wipe a thousand times as well.
I am able to mount the sd card briefly in ClockworkMod Recovery, to view the files on the sd card but then about a minute or less later the sd card seems to unmount itself and becomes unrecognizable. Same for when I connect the phone via USB to my Windows 7 PC. If I pull out the physical sd card from the device, put it back in, hit connect to storage...the PC will recognize it for about a minute basically teasing me, letting me transfer a couple small files...and then unmounts itself and stops being read. Because of this I cant seem to partition the sd card in Windows 7 nor can I get it to complete and Check Disk.
I even bit the bullet while trying to format the sd card in CWM, and then while connect to the PC and I cant even get the card to format...
Obviously I'd prefer to some how save all the files on there before having to format if possible.
Tried searching around the forums but nothing seems to be similar to my problem. The ONLY thing I can come up with for the cause was that I mistakenly flashed the charge.PIT file while flashing Tweaked 3 in Odin. Not sure if thats the cause...
Any help and suggestions would be great. Thanks!!
