davey11
Re: Galaxy Nexus Screen Shots! - Upload your here
Untill I get my Nexus, I kinda hate coming to this thread.
sfbates, is it possible to hide the text under the app icons? I can do this in Launcher Pro and have gotten used to it. It might be a bit annoying to have to see that text again!
Yeah, like there mine says "google". you can make the name of the app folder blank
as for the name under individual apps, there is no way, that i know of... but thats just from looking at my gnex for 30 seconds... but it's not made obvious that you can remover app names.
You can only have folders "unnamed"
Very similar to going into a strip club. Look but you can't have.
Thanks for the pics.
Did you unlock the bootloader yet? Root?
Should we pin this to the top? or have a Moderator create an official screen shot thread.
I could be mistaken but my guess is that the developer has to allow a widget to be resizable. Mostly for design purposes I'd guess (so that a 1x1 widget looks best, 2x1, 3x1, etc.)are all widgets now resizable or do the developers have to allow for that to happen? my guess is the latter because that's the way it is on my xoom.
But to answer the question, from playing in the SDK not all widgets are resizable so there must be a specifier
Yes but when you do many tend to get uglified from the resizing - because you're forcing a design for, say a 4x1 widget, into a 3x1 or 2x1 for example.I don't think that is correct. Doesn't launch pro allow you to resize all widgets?
Sent from my DROID BIONIC using Tapatalk
