I have a Samsung Galaxy S4 GT-I9505 unrooted mobile with a Samsung 64Gb Micro SD installed which I use mainly for music files synced via iSyncr and played using Poweramp.
It all works fine but when I have to re-start my mobile after I have turned it off the SD card is unmounting itself and I have to manually re-mount it in the storage settings. Do you know what could be causing this?
I have tried two different SD cards and even swapped my S4 for another one and I am still getting the issue. Could it be a fault with the S4 firmware? or maybe an app is causing the SD card to unmount during a boot up? Could it be iSyncr or Poweramp?
HELP!
ANSWER......
I found no solutions to my
satisfaction since my card wasn't faulty and I didn't
want to reformat. I will explain what worked for me
and what I hope will work for you.
1. Go to settings and press on Storage.
2. Then press Unmount SD Card. Allow the phone to
process.
3. After it finishes making it safe to remove, open
your case and remove the SD Card from the Slot.
4. Reinsert your SD Card in the Slot.
5. Restart your phone. Use phone as normal and
see if problem is solved.
IF it still not work. format it after the process above. it will be working properly.
