!!!HELP!!! Find RUU EE UK or another RUU can use it, No OS !!!HELP!!!
Ronan ronanz
3
i use twrp for wipe but i choose wrong, i choose format data lost everying. What should I do to get back to the same. I was not able to find any RUU of EE UK was enough to help me to find that there is another way, please help me.
Now my phone unlock already but S-ON (very bad for me) see my detail Told me that I should do so.
detail my phone
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.55.0000
(bootloader) version-baseband: 4A.21.3263.04
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main:
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: FA395W
(bootloader) imei: XXXXXXXXXXXXX
(bootloader) meid: 00000000000000
(bootloader) product: m7_ul
(bootloader) platform: HBOOT-8064
(bootloader) modelid: PN0710000
(bootloader) cidnum: ORANG001
(bootloader) battery-status: good
(bootloader) battery-voltage: 4279mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: dirty-b0a25cb2
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
thank you.
wizzrah
Retired Ambassador
Jul 27, 2013
4,686
detail my phone
thank you.
Can you mount the phone to your PC?
wizzrah
Retired Ambassador
Jul 27, 2013
4,686
Yes i can. But i don't know rom for flash my phone. U can guide for rom for EE UK
If you can mount, then you can drag in a ROM for your phone.
Here are the steps:
If you have questions with anything, let me know. Ask before doing.
Find a ROM here: One Android Development - xda-developers
You might need to upgrade to a newer version of TWRP. What version do you have?
Once you have downloaded a ROM, drag it into your phone and flash it. Once you flashed it, boot into fastboot.
Make sure it says "Fastboot USB"
Go to your PC. Download these ADB and Fastboot files: https://copy.com/MB4KJcNo6giYNw4
Put the folder on your desktop. Take the directory of that folder.
Open up CMD. Type "cd" and then paste the directory. It should be like this: "cd *directory*"
Go to the ROM you downloaded on your PC. Look inside the zip. There should be a file called boot.img.
Take the boot.img and put it in the ADB-Fastboot files folder.
Go back to the CMD.
Type "fastboot flash boot boot.img"
Let it flash the boot.img.
Reboot the phone.
Should boot then.
Ronan ronanz
3
Here are the steps:
Go back to the CMD.
Reboot the phone.
Should boot then.
i try flash many rom but not work.
i have a question
1. can i s-off in adb hboot 1.55 or not?
2. can i use nandroid CID ORANG001 for flash? guide me
thank for help
wizzrah
Retired Ambassador
Jul 27, 2013
4,686
Is there anyway to find the Info to get firmware and ota etc without connecting to pc ?
If you mean to find the correct RUU for your device, you just look under device settings to find what software version you are running. You can also look at hboot, firmware version, and more in the bootloader menu of your device. If you are going to flash an RUU to your device, you will need a PC.
M_Nabeel
Kindly give me the link of RUU
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.22.30306251.27G
(bootloader) version-main: 3.33.401.10
(bootloader) version-misc: XC SHIP S-ON
(bootloader) serialno: HT413MY00002
(bootloader) imei: ********** //Some Number
(bootloader) imei2: ********* //Some Number
(bootloader) meid: A1000037B5223C
(bootloader) product: m8_dugl
(bootloader) platform: hTCBmsm8974
(bootloader) modelid: 0P6B64000
(bootloader) cidnum: 11111111
(bootloader) commitno-bootloader: 4c3fbd70
dxter
