help! screen is unresponsive need to reset counter before return
1moneymark
24
help. my screen has become unresponsive. i need to return it. i can still unroot but is there a way to reset counter without running triangle away on phone?
Thanks
jhill110
247
Thanks
Here's a link that will set you back to totally stock with 1 flash with stock recovery, reset counter as well as reset device status to normal from modified (often overlooked).
[ROM/RESTORE][!MD4 OTA!](5-10)Quick Return to UNROOTED STOCK WITH FLASH COUNT RESET - xda-developers
Just make sure you select the right file to flash (16gb or 32gb)
Good luck.
ukfred
