Help with cm7
illinoissparks18
113
8
I'm running Scott pilgrams cm7 and I constantly get a notification for voicemail. Is there aa way to disable this? Thanks.
hlxanthus
1,790
411
Hate to say it, but that version is no longer supported. Thekravens cm7 is the newest iteration out there. I would try that and see if that fixes you problem.
pergerson6
1,113
72
You could try Google voice. Its not stock VVM but installed and integrated correctly works just as good.
aaronrw
451
66
Are you able to kill voicemail manually then reboot or something? I ran kravens cm7for a while with no problems however:what:
hlxanthus
1,790
411
On thekravens cm7 in the first post toward the bottom, there is a section called hotfixes. #7 is the sprint vvm fix, that removes the 9017 text notification about voicemails.
GeneralCaveman216
