MarkSeven
I just did the software update. Not really sure what it's supposed to improve exactly but whatever. It better not mess it up!
from Wally World.
what software update? ...is this a official Google/Android upgrade?
It's called Wally World because the employees don't have a clue about anything! Just like John Candy in the original version of Vacation with Chevy Chase.
Sent from my Nexus 7 using AC Forums mobile app
Lol true that. Some do but many don't. About the tablet is it worth buying it or should I wait for the new Nexus 7.
Sent from my SPH-L720 using AC Forums mobile app
I grabbed a few USB cables and started plugging the tablet into my laptop.
A variety of things happened depending on the cable.
The cable that came with the Sero.
It would charge and you could copy/move files, to/from the tablet.
Cable from my S3 would only charge.
1 Generic cable was data only
2nd generic cable would only charge.
On all the cables that would charge, the touch screen touch points were off slightly.
When I plugged the tablet into my S3 charger, the screen was way off. Trying to unlock with a pattern was almost impossible, took 3-4 tries.
Sent from my SCH-I535 using AC Forums mobile app
I'm having a problem playing a videos stored in the SD card. I've uploaded avi and mp4 videos to my external sd card (64gb) and it seems only certain mp4 videos are able to play. After connecting the Sero 7 to my PC with the usb cable I move the files into the SD card folder. When I looked in the folder where I've uploaded, files that work shows the duration of the movie and ones that doesn't work shows only 00:00:00 duration or just the size of the file. I've tried converting avi to mp4 using the bigasoft total video converter with profile for Android MPEG4, but that converted file still didn't play in the tablet. I can't seem to figure out what format is causing the problem. Has anyone tried this?
Today I used ES File Explorer to delete some files from my SD card. Everything looks as it should on the tablet, but when I plugged it into my computer to transfer more files, I had a bunch of "LOST" folders show up, some of which contain empty copies of the deleted files, and also there are multiple copies of the folder that I had deleted the files from, some of which contain empty copies of the deleted files. Then there's one that contains a folder called "local disk", and inside that is over a dozen more folders called "local disk"!
I wonder if this is related to the problem someone here was having whereby he kept having multiple copies of his sdcard pseudo-directory show up?
I rebooted the tablet and they're still there.
I don't have anything on the card that I don't have other copies of, so I'm tempted to format it in a Linux filesystem instead of whatever it was (NTFS?) and see if it does the same thing.
