How can I reboot my Android if my phone won't allow me to?
sparklingmagma
Android stuck at "Dead android with red triangle" Cannot shutdown either
Hi, I just got my android yesterday so no it wasn't rooted or anything, I didn't install anything that involves with rooting. When I shut my android down yesterday so it wouldn't use the batteries and turned it on tomorrow (today) it shows me a dead android with a red triangle, I pressed the wrong button instead of reboot system and now I can't change my option and it wouldn't let me reboot after holding my power button for 10 seconds
Help!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,675
4,823
113
Re: Android stuck at "Dead android with red triangle" Cannot shutdown either
Welcome to Android Central! Which device is it? When did you press the wrong button--when you saw the dead Android with the red triangle? Do you remember what the wrong button said? What screen is it on right now?
You can usually force a power off by pressing and holding the Power button for a long time. You might have to hold it for longer than 10 seconds--maybe 15 or 20.
