How i learned to flash a ROM
drinkhere
100
Hi DroidXcon can you help me to get ROM/Kernel: SuperDark/StupidFastV1.76 on my fascinate please im new to this staff and i dont know where to start. i rooted my fascinate already thanks to you but i would like the rom and kernel you have please help me out thanks.
mike_langley
Active member
Nov 14, 2010
27
Excellent! One last quick ques - I noticed after flashing that SC DL09 .4 doesn't have a modem with it. Can I flash the modem now, or should I go back to stock & start over?
Big thanks for all the help!!!
DroidXcon
11,102
3,392
no roms are roms, as long as they are compatible with DL09 you are fine
when flashing a rom kernels and modems stay put, all you are changing is the OS not the modem or the kernel
Reactions: mike_langley
HellBoundSinner
3
Is there a specific order it needs to be flashed in. Like ROM first, then modem, then kernel? Just wondering. Modem needs to be done in ODIN..got that..and the rest through CWM. Any specific order though?
DroidXcon
11,102
3,392
Droidx I flashed my phone using Odin to DJ05 and it worked great, check my posts for the link, its an all in one package.
yeah i have that file myself, im adding it to my new thread on reverting to stock and using Odin that im working on..
Glad that worked for you ,,,
PS told you odin is sensative with how its connected
AsianGloBo
23
Im pretty new to Flashing and curious. I have installed Odin and flashed CWM onto the phone, downloaded ROM Manager and rebooted with CWM. I am now on this step:
And im downloading the Three Part files:
Radio:
http://rom.galaxysense.com/adrynalyne/dj05modem.tar
http://backup.galaxysense.com/adrynalyne/dj05modem.tar
This gets flashed via Odin, in the PDA section.
System/rom:
http://rom.galaxysense.com/DJ05_stock.zip
http://backup.galaxysense.com/DJ05_stock.zip
This gets flashed via clockwork.
Kernel:
http://rom.galaxysense.com/1212_test_novoodoo_fascinate
http://backup.galaxysense.com/1212_t...odoo_fascinate
The ones in the Red, im not able to download. Do i need these?
DroidXcon
11,102
3,392
Radio:
System/rom:
Kernel:
why waste your time,,,http://forum.androidcentral.com/ver...ckworkmod-recovery-return-stock-use-odin.html download the full package tar from post 3 then follow directions in post 4
Reactions: AsianGloBo
DroidXcon
11,102
3,392
Thank you very much. Downloading now. Thanks again for all of these helpful tutorials!
you are very welcome, please let me know if you need any further help,,,also a titanium backup may be useful or if you have clockwork installed a nandroid would be great.. and also dont forget to back up contacts
AsianGloBo
23
Ok, so i flashed DJ05.tar file, and my phone is running AWSOME *in high pitched voice. But i didnt know it would erase all my apps, and contacts. So i have Re-rooted again with no problems, and downloaded ROM Manager. My question is, do i have to run the FlashClockwork Mod again?
DroidXcon
11,102
3,392
Sorry about that , thats why at the top of the post where you got the DJ05 file it says it will wipe everyting thats not on your SD card
yes if you want to use clockwork for DJ05 follow either section 2(green clockwork) or 3(red clockwork) in post #2 of that same thread
AsianGloBo
23
sweetness man. Ok now im having a problem. lol. I accidentally deleted the nuance android vsuite file on root explorer. Now i keep getting a pop up the app has stopped unexpectedly, and soon as i force close it pops up no matter what i do!
AsianGloBo
23
wow, the one file i delete is the ONE file that was said NOT to delete. Im currently running this process:
ODIN] Full DI01 ODIN Package
I hope it will fix it, so i can start from scratch
DroidXcon
11,102
3,392
yeah flash odin again if that doesnt work we will try something else
HelloThere
