Woody_Thrall
Hanging on factoryfs.rfs
First off I'd like to thank this community for all the support they've provided all along. I'm hoping that someone out there will be able to help me out today. I've used Odin before, but this time around I've hit a wall.
I'm trying to Odin SPH-D700-EC05-8gb-REL.tar onto my Epic and I'm constantly hanging on the factory.rfs portion.
I'm using a WinXP 32 bit desktop with the correct drivers.
Anti-Virus disabled.
Battery and SD card removed.
Have successfully Odin'd with this cable before and have tried multiple USB ports.
Can power phone into Download (digger) mode and Odin 1.61 recognizes it.
I select the file above in the PDA field, no PIT.
Check only Auto Reboot
Start
Everything if fine until I hit factoryfs.rfs whih then hangs without a failure (15 minute wait time)
Pull the plug on the phone, try again. I've been at it all day at this point.
I've tried variations with and without a PIT, but I'm still stuck in no man's land.
Any suggestions?
Thanks again!
Start
Any suggestions?
Thanks again!
